YWFE710H0BS0 Whirlpool Range - broil element on when bake
cactuslizzie
canada
YWFE710H0BS0
i was trying to bake something, got the message "feature not available". after a while, the message disappear. the oven went on, saw the temperature going up very fast, the broil element was on even the temp reached the 350 deg. stopped everything, went on the internet to find answers. tried everything i found ( unplug for 20 min the plugin, checked the bake element , is OK )
i believe i need a new oven control board. can i have the part number for this control board ?
thank you for your time to answer me
Yes, you will need to replace the clock oven control board.
Here's the clock oven control board for your model you can order:
Main Control Board WPW10340304
cactuslizzie
canada
thank you for your fast answer. i'll try to disable the broil element, if is not working i'll look for another range.
Sounds like a plan. (y)
