FIXED YWMH76718AB2 Whirlpool microwave open/close door error
Gtmoyer
Florida
YWMH76718AB2
model no YWMH76718AB2
Getting open / close door error continually will not reset
From other posts it appears that this may be a switch issue... can someone confirm part numbers for replacement switches my model?
I also saw something about a blown buss fuse.. would that apply to this model
Attached photo showing model no
Gtmoyer
Florida
Ok... I did the continuity check on the switches... bottom switch shows open in either position.. I assume that is the bad switch
Gtmoyer
Florida
Ok.. I changed switch.... now microwave turns on for half a second then back off...
Did I reinstall incorrectly?
Screen goes to "press start"
Gtmoyer
Florida
I think I got it working, changed lower switch... had to adjust it.. then it was working
Thanks for the help
