- ZDT925SSN2SS
- GE
- 1-5 years
So I am having multiple issues with this dishwasher. The main issue is the unit will shut down without any error as the amber light will just turn off as if I never started the dishwasher. It happens in the first 10 minutes of starting the dishwasher give or take depending if there is water present in the dishwasher. I did a bit of trouble shooting and thought the drain pump failed as the dishwasher would shut down when it trying to drain the water in the dishwasher. I ordered a new drain pump. It ran great the first and second time. The third time, its doing the same thing even though the drain pump is able to drain the dishwasher. Now I am just lost.
Second is the pump. It leaks!! I thought I installed it incorrectly and reinstalled it. It still leaks. Then I took it apart and put in silicon grease (I use that for the seals in my pool pumps), it still leaks. Its a very slow leak, maybe a drop every minute. Enough for the sensor to trip and give a leak detection error after about 30 minutes of running. Could it be a bad pump? It took GE over a month to send me this pump as it was on backorder.
