- ZFSB23DRHSS
- GE
- 6-10 years
A friend has the above model, side-by-side. Freezer is set at 0 degrees, readout on frig is 0-1 degrees, and confirmed by thermometer. Frig is set at 36, readout is 44-45 (pretty consistently), and thermometer reads 38-50 - obviously varying widely. Cold air blows from the vents in the back of the frig. Can hear fan(s) running much of the time.
Removed freezer coil cover and am including a photo. Manually defrosted coils and reassembled. In about two hours frig was down to 34 (by thermometer); readout was still 44.
I'm guessing thermistor might be bad (readout inaccurate, fan running too much). How many thermistors are there that should be tested and where are they? How do I test them? Anything on the computer board I should be checking? If so, what and where is it?
Thanks for your help!!
