- ZIC360NR
- GE
- More than 10 years
GE Monogram Bottom Mount Inverter Compressor "built in" Refrigerator ZIC360NR -- Condensate drain line to evap pan blocked or broken. Have reviewed Technical Service Guide and removed vertical back channel panel to no avail. Condensate drainage pooling and freezing at bottom of freezer (turned off and disconnected water line to ice maker and problem continues - evap pan is always bone dry). How can I access (or replace) the condensate drain line that empties to the evap pan to clear the blockage or repair the break? Thanks!
