Jimmy W
- ZISS420DRISS
- GE
- More than 10 years
I have a GE built in and that has the freezer set to 0 deg and FF side set to 35. The freezer is now -12 deg with the FF side at 50 deg. I read as many post on this board as possible and thought it may be the damper, so I took apart the foam around it so I can see it. I ran a diagnostic 1,6 and the damper opens and closes. I also read that perhaps I had a bad evaporator fan. I don't understand the air flow enough to know when the evaporator fan should turn on. I am assuming that is should turn on to blow cold air into the FF side with the damper open. I can see the fan from the FF side and it is not running. The only time the fan will run is when I have kept the freezer door open for more than a few minutes.
Any help would be totally appreciated.
