I went on this service call because the customer said the washer was not spinning and leaving the clothes wet. When I arrived I found the door latch lock switch assembly broken.
Here’s the door latch lock switch assembly for this model:
Latch Actuator W11307244
W11307244 Latch
Procedure to Remove Lock Assembly:
Use the following procedure to remove the new lid lock assembly from the washer top panel.
1. There is an embossed emblem of a lock on the right-hand side of the lock bezel (see figure 1).
2. With a thin plastic putty knife or small flatblade screwdriver, lift up the side with the lock emblem and slide the lock assembly to the right (see figure 2).
3. Next, tip the left side downwards and guide the lock assembly down through the opening (see figure 3).
4. Reverse this procedure to reinstall the lid lock assembly.
figure 1
figure 2
figure 3
Western Arizona Weather:
Today
Partly cloudy. Highs 67 to 72. Southeast wind 5 to 15 mph.
Tonight
Partly cloudy. A slight chance of showers and thunderstorms in the evening, then a slight chance of showers after midnight. Lows 44 to 54. Southeast wind 5 to 10 mph. Chance of measurable rain 20 percent.
Friday
Partly sunny. Highs 65 to 70. Southeast wind 5 to 15 mph.
