1997 Sears Kenmore washer (model#110.26912691): Not agitating or spinning, but you can hear the motor running. Took the cabinet off, then removed the water pump and motor, then I saw the motor coupling broken, and lots of oil coming from the gearcase. I showed the customer the oil leak and they said, we have had good use from it, and its time for another new Sears Kenmore. I agreed.
Here’s the motor coupling for this model, in case others without an oil leak what to order and change it.
Manufacturer part number 285753A is RepairClinic item number 1195967
285753A
