Hi all,
Very nice sunny day here in Western Oregon, Temps. in the 80’s, after a week of much needed rain. 🙂
2001 Kitchen Aid Dishwasher
When filling with water, the water solinoid was knocking, like a water pipe vibration. Replaced water valve, worked great.
Customer was complaining of dishes not getting as clean. Installed new check valve and chopper blade assembly in sump(pump). Chopper was broken. The check valve is the small rubber flapper in sump(pump) that can stick and not allow proper water flow to spray arms. Replaced both, worked great.
2002 Kenmore Frigidaire built Window Air Conditioner
Kenmore 12,500 BTU Multi-Room Air Conditioner
Compressor was out. Replaced Compressor, worked great.
Replacing a Compressor is major job, takes about 3 hours.
You need to be a certified Type 1 40 CFR part 82, subpart F. AHAM-NARDA Refrigerent Tech. to change Compressors or do any sealed system work involving Freon(Refrigerant Gas). I got certified on 11-17-1994 when i worked for The Montgomery Ward Service Dept.
Thats it Today.
Have a Good Evening!
P.S.
The Forcast Here in the Southern Willamette Valley of Oregon for Sunday 8-29-2004:
Sunny after patchy morning fog. Highs around 85. North wind 10 mph.
