I found the ice maker not making any ice at all, the ice maker would cycle but not put water in the ice maker tray. I volt tested the electrical connector that goes to the ice maker water inlet valve solenoid while the ice maker was cycling, and my multimeter was only showing 48 volts AC, and that ice maker water inlet valve solenoid needs 120 volts AC to put water in the ice maker tray.
I replaced the ice maker and it worked great, I could hear and see the water going into the ice maker tray.
Here’s the ice maker for this model:
W10882923 Icemaker
W10882923 ice maker
